Hi yani,
Is it possible in the future to have support for the original ELS27 v4 interface?
At the hardware level it supports the KKL function and is wired on pins 1 & 9 yellow connector is pin 3 & 11 blue connector.
From the manufacturer's website I learn that this is an alternative function - this is a protocol that can be enabled on this contact when the relay is activated in the adapter. The relay is activated by a specific command and for this there must be support from the software side.
Link info: https://els27.ru/index.php?route=information/information&information_id=7
Sorry for my English!
Thank you
Support for original ELS27 v4 interface
Re: Support for original ELS27 v4 interface
Commands for configure ELS27
KKL mode:
STGPC28:O Configure general purpose pins
STGPOW28:1 Write output latches
No use interface KKL line!!!!!!!!!
ELS27 device is in raw KKL mode.
To return to normal mode you have to unplug both OBD (16-pin DLC) and USB ends of the cable and connect it again after that.
MM_CAN switch relay pin 6&14 to pin 1&8/9:
STGPC35:O Configure general purpose pins
STGPOW35:1 Write output latches
ELS27 device is in MM_CAN mode.
No use YELLOW adapter 3!!!!!!!!!!!!
MS_CAN pin 6&14 to 3&11:
STGPOW35:0 Write output latches
ELS27 device is in MS_CAN mode.
No use BLUE adapter 5!!!!!!!!!!!!!
KKL mode:
