2014 Fiat 500 Abarth (North American) - Upgraded instrument panel to TFT
Partnumber of the Display: 735687357
In fact it is a speedometer for Abarth Restyling and if you mount it in an old 500 from exactly the defects described by you.idlop wrote:Partnumber of the Display: 735687357
And what is about one from Serie 3/ 2014 ?
They do not have uconnect. This will Works?
Like: 735633917 ?
Like: 735633917 ?
AbarthDriver wrote: ↑24 Dec 2016, 22:43 Hello,
This is most likely going to be for Yani, but...
Car:
2014 FIAT 500 Abarth (North American model)
What I did:
- Removed older ANALOG instrument cluster.
- Put in 2015 Abarth TFT instrument cluster when car ECU KMs matched the cluster.
-> Flashing odometer (to be expected).
- Performed Proxi Alignment, TFT switched to a base Fiat 500 TFT and no longer displays the Abarth TFT graphics.
Is there a quick way to fix this via a menu item or custom command?
Thanks!
I want to use with Torque Pro, can someone please give me the commands for odometer reading that can be used with Torque Pro?
Hello. I have a problem my car is 500 Abarth since 2013 purchased from North American. I tried to change the instrument panel with TFT with Partnumber 7356197460 but I have a small menu and turbo meter does not work flashes and the time indication and does not change my start logo after proxy rejoining gives me the following error error U1700-86 no body computer and U1706-86 NFR Node absent. I am interested in can i fix how and how, and this TFT whether it has a Reset function and how it is done.
Is it possible to do this update with the iOS / iPadOS version of the app?
I changed byte 65 to get the Abarth style on the cluster to 60 and I get other fiat 500 turbo look and the boost gauge doesn’t even light up. Does anyone know the solution to this?
