2007 fiat punto selespeed p060c
ams
Post by ams »
Hi I have a 2007 fiat punto selespeed and it wont engage any gears, clutch has been checked and it comes up with a fault of p060c COntrol unit faulty (microprocessor)
I have tested the relay and that works
I can hear the pump priming every so often as well
I have tried disconnecting and reconnecting the big plug that goes to the gearbox
Is there a seperate ECU for the selespeed and if so any ideas where its located?
JFerris321
Re: 2007 fiat punto selespeed p060c
Post by JFerris321 »
Hi, i know this is an old post but i have also got this problem on my car, did you ever get it resolved or has anyone else had experience with this problem?
Incidentally if it is of any help the selespeed ecu is located under the plastic panel on the passenger front floor carpet.
