Ultraboss
Post by Ultraboss »
I've bought a bluetooth interface to use it in my Giulietta on my phone with Torque and on PC with MES.
My interface is an iCarSoft i620 (http://www.icarsoft.com/web/icarsoftus/ ... lk3_1.html) witch is compatible with all ELM327 protocols :
• SAE J1850 PWM(41.6Kbaud)
• SAE J1850 VPW(10.4Kbaud)
• ISO9141-2(5 baud init,10.4Kbaud)
• ISO14230-4 KWP(5 baud init,10.4 Kbaud)
• ISO14230-4 KWP(fast init,10.4 Kbaud)
• ISO15765-4 CAN(11bit ID,500 Kbaud)
• ISO15765-4 CAN(29bit ID,500 Kbaud)
• ISO15765-4 CAN(11bit ID,250 Kbaud)
• ISO15765-4 CAN(29bit ID,250 Kbaud)
• SAE J1939 CAN(29bit ID,250*Kbaud)
• USER1 CAN(11*bit ID,125*Kbaud)
• USER2 CAN(11*bit ID,50*kbaud)
It works well with Torque but I can't connect to ECU (link problem) even all commands test are OK...
I've tired all link rates, buffer/no buffer (in advance COM port configuration link, trough Windows devices management).
I've a generic Bluetooth dongle.
Tested with MES 2.5 on Windows 8.1.
I've just sent a report (15h20 GMT+2)
Thanks for helping me
Hello Ultraboss
Whether this interface is compatible with MES, I do not know
Point times connect to the interface and press in
MES / Settings / Interfaces / Test button
And adjust the screen here to see whether the interface with MES works
Ultraboss
Post by Ultraboss »
Hi Eddy,
this is my test results :
RESPONSE: ATZ
ELM327 v1.5
ELM327 v1.5
Cette interface est compatible avec ELM 327 1.4! Devrait pouvoir se connecter correctement avec tous les modules CAN.
Do you need something else ??
Hello Ultraboss
After your screen your ELM should work.
So can make the connection issues only the bridge resistor
On many pages in this thread almost all ELM interface are listed
and marked the bridge resistor from me.
Otherwise, a good picture of your board and make the site a Image here
Ultraboss
Post by Ultraboss »
I've already thought of this and tested pins 6 & 14 with an ohmmeter, they are not connected...
magnetic
Post by magnetic »
Greetings! I have a little problem with ELM327 (bt) v2.1
I bought this item on ebay : http://www.ebay.com/itm/141503501603?_t ... EBIDX%3AIT
and this not working on my vehicle : Chrysler voyager 2003 but it's working on vw passat 2007.Can not find the ECU.
Any ideas what's wrong? :(
Thanx.
Hello Magnetic
Here the theme is about Italian cars and Multiecuscan
Your problem has something to do with the software you want to read with your vehicles.
persia
Post by persia »
elm327 v1.3 linea 1.3 multijet service ınterval reset connectıon faıled problem please help!
Hello Persia
This pass (Resistor + capacitor) I have not have to solder in any interface.
Neither current interface I did not get to run it.
But where you have v1.3 Interface ago ????
I've not seen.
Because they had no resistor bridges
But when I see in your screen you have a comport of another driver needs.
Try it once with this driver
http://www.silabs.com/products/mcu/Page ... ivers.aspx
And remove the self-soldered components
Crazymecano
Post by Crazymecano »
Hello Guys,
I purchased a ELM327 bluetooth from e-bay to use it on my Vauxhall astra 2001 1.8 16V. I can't connect it currently with Scanmyopel lite on Android 4.4.2 "No response from ECU".
I started to read topics about to add compatibilty by soldering pins 3-7-12 together , but before to try any hardware modification I would like to confirm which ELM323 I have got :mrgreen: , I was looking for V1.4 (apparently most compatible version) but when I opened the box it doesn't look like something I can identify :o :
Which version of ELM327 do you think it is ?
Do I have to perform any hardware modification to get it working with my configuration :twisted: ?
Thanks in advance for your help.
Romain
