Selespeed
devc
Selespeed
Post by devc »
Thanks Yani for implementing the oil pressure and other parameters on the Selespeed EOL test on the Alfa 156.
However the most EOL test failure problems are insufficient oil pressure and low battery voltage.
The temperatures on the gearbox and clutch are not realy important.
So could you please change the temperatures to battery voltage and also please add this feature to the Alfa 147's
Thank you,
Dev Cloete.
