dimcaras
Posts: 2 Joined: 16 Sep 2011, 17:26
Post
by dimcaras » 29 Nov 2014, 10:14
I try to connect to a Fiat Cinquecento engine code 1170A1046 but the system hang up.
I use interface OBDkey 1.4 with 3pin adapter. Pinout to 16pin female such in attachment picture.
I send also the log files and the foto of engine electronic unit IAW 6F.S0.
Please for help
FESLog_1411281623_Fiat Cinquecento 903 i.e Eco.txt
LOG FILE (210 Bytes) Downloaded 492 times
ECU ECU.jpg (70.02 KiB) Viewed 6108 times
ADAPTER 3PIN 3PIN.jpg (34.62 KiB) Viewed 6108 times
Posts: 870 Joined: 12 Feb 2010, 09:03
Post
by alfa156sarajevo » 07 Dec 2014, 18:44
Which year is Cinquecento?
Did you try to connect it with IAW scan?
Sometimes old ECUs are not supported.
For older Fiat and Alfa cars you need some other software.
dimcaras
Post
by dimcaras » 07 Dec 2014, 20:52
Thank you for the post.
The manufacture year is 1994.
I have downloaded the application "IAW Scan 2" version v0.82.
Is there any newer version?
The 3pin adapter that I use is homemaded by me and I putted no resistance at all within.
Is the 3pin adapter correct?
Post
by alfa156sarajevo » 15 Dec 2014, 21:41
Connection schematic for 3 pin connector is OK. No need to do any other modification
tzok
Posts: 172 Joined: 11 Mar 2010, 21:45
Post
by tzok » 19 Feb 2015, 14:07
This ECU requires an ISO-KKL cable (also known as VAG-COM 409.1).
Posts: 180 Joined: 18 Dec 2013, 18:22
Post
by Waltomatic » 20 Feb 2015, 10:33
tzok wrote: This ECU requires an ISO-KKL cable (also known as VAG-COM 409.1).
Damn... OBDKey supplies KKL and ELM.
