I think this is related to the ELM327 issue, but my ELCM327 appears to have a different circuit board.
I cannot connect to SERVICE so I can reset the oil change warning.
I removed R14 on the cuircuot board but this is a 670 ohm resistor, not 100k. So after trying to connect which no improvement I have resoldered R14 back on.
What do I need to do to make this work? Car is an Alfa 159 2.4D 2007.
Cannot connect or scan any modules except ENGINE
Re: Cannot connect or scan any modules except ENGINE
Hello EFA
The removal of R14 is wrong!
You must remove R04 , then the CAN bus to read log
This ELM has been repeatedly described in Thread
Thanks. 18000 miles until next time
