Multiecuscan 1.9 released!
I released Multiecuscan 1.9 today with the following changes:
- Fixed "scan for interfaces" function to avoid false recognition of KKL interface
- Support for PROXI deactivation/activation of TPMS function
- Support for PROXI deactivation/activation of Stop@Start system in body computer (Grande Punto, Evo, 500, Mito, Giulietta)
- Added new actuators for Siemens Instrument Panel (159/Brera)
- Support for Magneti Marelli IAW 18FD Injection (Punto, Lancia Y)
- Support for Magneti Marelli IAW 18F Injection (Palio, Punto, Tempra, 145, 146, Dedra, Delta)
- Support for Magneti Marelli IAW 16F Injection (Cinquecento, Seicento, Punto, Panda, Palio, Uno)
- Support for Magneti Marelli IAW 06F Injection (Cinquecento, Panda)
- Support for Magneti Marelli IAW 08F Injection (Punto, Tempra, Tipo, 145, 146, Dedra, Delta)
- Support for Magneti Marelli IAW 06F Evoluta Injection (ECO) (Cinquecento, Panda, Punto)
- Support for Magneti Marelli IAW G7.XX Injection (Fioriono, Uno, Tempra, Premio)
- Support for Magneti Marelli IAW 1G7 Gasolina Injection (Fioriono, Uno, Palio)
- Support for Bosch EDC17CP52 CF5/EOBD Diesel Injection (3.0) (Ducato 250 Facelift)
Re: Multiecuscan 1.9 released!
Hi Yani,
In this version of MES you have fixed proxy on panda 169 ? It failed on all version "multijet,bipower ecc"
How, comprehensive diagnosis for dual-zone climate, blue & me of grandepunto?
Tanks.
I have your cantiecar v3.1
Tanks.
Thank you for the IAW-x6F/x8F support!
I've found some differenced to my IAW ECU Scan 2:
2014-03-20 16:30:32
IAW Scan 2 [v0.81]
CONNECTED TO:
Punto 55 1.1 SPI 5M/6M ECE F2
Magneti-Marelli IAW-6F/16F SPI
ISO Code: 55-D0-85-02-94-40
Spare Part Code: 61602.063.01
BŁĘDY:
ECU not synchronized with CODE FIAT CODE [A]
PARAMETRY:
Engine Speed: 0 RPM
Injection Duration: 0.00 ms
Ignition Advance: 10.00 °
Manifold Absolute Pressure: 1000 hPa
Air Temperature: 21 °C
Water Temperature: 21 °C
Throttle Opening Angle: 8.04 °
Battery Voltage: 12.25 V
Lambda Probe Correction: 1.00
Idle Stepper Motor Position: 90 steps
Idle Stepper Integral Gain: 0
Idle Stepper Proportional Gain: 0
Trimmer Position: 0 steps
Autocalibration Correction: 0
Autocalibration Correction with A/C: 4096
Idle Engine Speed: 0 RPM
Idle Engine Speed Offset: 0 RPM
Stepper Correction (Delta): -108
Stepper Correction from FLT: 0
AC Offset Parameter (min. load, EVAP off): 0
AC Offset Parameter (min. load, EVAP on): 0
AC Offset Parameter (min. load): 0
AC Gain Parameter (med. load): 0
Engine Running: NO
Sensor Signals OK: NO
Throttle at Min/Max: YES
Lambda Sensor in Closed Loop: NO
Air Conditioner ON: NO
Mixture AutoCalibration ENABLED: YES
Stepper AutoCalibration ENABLED: YES
Power Latch Line OK: YES
ECU ISO Code: D0 85 02 94 40
3/20/2014 4:06:21 PM
CONNECTED TO:
Fiat Punto 55
ECU ISO code: D0 85 02 94 40
Spare parts code: 6160206301
READING ERROR CODES:
1:
The fault is present now. Take appropriate action to fix this sensor fault.
READING PARAMETERS:
Engine speed: 0 rpm
Engine temperature: 21 °C
Air temperature: 21 °C
Intake pressure: 1000 mBar
Spark advance: 10.0 deg.
Injection time: 0.000 ms
Throttle valve position (absolute): 8.0 deg.
Idle actuator (Step motor): 90 steps
Adaptive idle opening: 0 steps
Adaptive idle opening (Clim. control): 4096 steps
Idle actuator steps delta: -108 steps
Idle actuator steps manual correction: 0 steps
Desired idle RPM: 0 rpm
RPM offset at idle: 1024 rpm
Lambda sensor correction: 1.000 %
Lambda sensor status: Open loop
Trimram: 0 %
Battery voltage: 12.38 V
A/C Compressor: OFF
Universal code: Not received
Engine start permission: Allowed
What is the problem with PROXI and Panda 169?fiatuno wrote:Hi Yani,
Tanks.
Never completes the procedure by latching onto the instrument panel.yani wrote:What is the problem with PROXI and Panda 169?fiatuno wrote:Hi Yani,
Tanks.
I have tried both on mjet MY05, bipower 2009 1.2 petrol 2008. Still the same problem.
I tried with ELM327 and CANTIECAR "MES" 3.1 updated.
Regards.
That is very strange. It is possible to have problems with some ELMs, but there should be no problem with the CANtieCAR. Can you send me a report (from the red Send Report button in Multiecuscan) after trying to do the PROXI alignment.fiatuno wrote: Never completes the procedure by latching onto the instrument panel.
What kind of error do you get? Timeout, configuration not supported or other?
Hi,yani wrote:That is very strange. It is possible to have problems with some ELMs, but there should be no problem with the CANtieCAR. Can you send me a report (from the red Send Report button in Multiecuscan) after trying to do the PROXI alignment.fiatuno wrote: Never completes the procedure by latching onto the instrument panel.
I send you log of fiat panda 169 "proxy fail".
The error is on dash "unknow error".
Tanks.
It seems that you are trying to do it through Bluetooth. Please try with direct USB connection.fiatuno wrote:Hi,yani wrote: That is very strange. It is possible to have problems with some ELMs, but there should be no problem with the CANtieCAR. Can you send me a report (from the red Send Report button in Multiecuscan) after trying to do the PROXI alignment.
Tanks.
Hí Yani , thanks for the new release.
My car is a Fiat Linea 1.8 16v year 2012 , Gearbox selespeed is CFC-319 , but not supported by Multiecuscan yet !!!!
some support in next release ?
many thanks for the info.
Ok, i test with usb connection.yani wrote:It seems that you are trying to do it through Bluetooth. Please try with direct USB connection.fiatuno wrote:Hi,yani wrote: That is very strange. It is possible to have problems with some ELMs, but there should be no problem with the CANtieCAR. Can you send me a report (from the red Send Report button in Multiecuscan) after trying to do the PROXI alignment.
Tanks.
