rockambole
Post by rockambole »
noob question:
how to open the elm 327 case? there are 4 holes under the sticky but none has screws
In so far all ELM or OBD interface has always screws was present.
Only some are the Kia you only a Phillips screwdriver
No. 0 to rotate.
gieboue
Post by gieboue »
Hi Alfaeddy, can you help me? My wifi elm327 appears not to work, only access to some ECU, how can i fix it?
IMG_1542 (Medium).JPG (157.65 KiB) Viewed 6869 times
IMG_1541 (Medium).JPG (182.14 KiB) Viewed 6869 times
IMG_1540 (Medium).JPG (212.65 KiB) Viewed 6869 times
gieboue
Post by gieboue »
and more fotos
IMG_1544 (Medium).JPG (127.69 KiB) Viewed 6869 times
IMG_1543 (Medium).JPG (140.55 KiB) Viewed 6869 times
Hello Gieboue
Your pictures are unfortunately very indistinct
Remove still please the wifi unit as it looks like the only plugged.
and make another picture,
So I can not see anything.
gieboue
Post by gieboue »
i am sorry. are those better?
IMG_1547 (Medium).JPG (175.19 KiB) Viewed 6865 times
IMG_1546 (Medium).JPG (177.14 KiB) Viewed 6865 times
Hello Gieboue
Unfortunately not, I can no pins and traces track
Did you not have a camera with macro function?
Besides these do not use a flash
A better picture of the area outlined in red please.
IMG_1547 (Medium) markiert.jpg (101.68 KiB) Viewed 6851 times
juanito
Post by juanito »
Hello there.
I have a problem for modifiy elm327 v1.5 bluetooth.
How can i do it. Pls help.
Hello Juanito
What is the problem?
What car?
Which control can not you read?
juanito
Post by juanito »
my car is fiat linea 1.3 mj 95 hp 2013 i want to open my cruise control but my elm is not modify.
how can i modify my elm v1.5 bluetooth. one of people say cut r04 another of says r14. what am i doing
