Hello Jos
You dont need a Adapter with Service reset
but you must remove the resistor R04
this you can read more and more in this Thread
jdijk
Post by jdijk »
Hello Eddy,
Thanks for your quick reply.
There is indeed a lot written about it, but I wanted to make sure.
Thank you very much!
Jos.
igna
Post by igna »
Hello, Alfaeddy, please, can you help me?
I have a alfa 159, and a elm 327 bluetooh, I have to remove r4 of my elm327?
http://imagizer.imageshack.us/v2/800x60 ... 9/rmy9.jpg
http://imagizer.imageshack.us/v2/800x60 ... 2/xisu.jpg
Hello igna
Are you sure this resistor R4 and the bridge resistor is??
You can pull the upper board and then get a better picture.
Hello igna
No, do not remove R4, this is the wrong Resistor
As I have already written, remove the upper board
and below is the R2, it must be removed.
ELM mini markiert.jpg (225.77 KiB) Viewed 8075 times
Gatter
Post by Gatter »
Hi Alfaeddy!
I used this driver from the first times with my first ELM. But only can read the engine ECU nothing more.. It's time to WIN reinstall.. :)
Otherwise today I made a successfull Remote Control programming on Fiat Stilo. So everything is good. :mrgreen:
tac51415
Post by tac51415 »
Alfaeddy wrote:Hello tac51415
Unfortunately, you can read on your screen no labels.
But it looks like the resistor R4 is concerned
Hi Alfaeddy,
I removed this morning R4 on my ELM board, and it's works like a charm ! (engine, dashboard, interval reset, body computer..) (Alfa 159 2.4 JTDm)
Thank you for your contribution!
Greetings From France!
Gatter
Post by Gatter »
Today I reinstalled the WIN7. Now ELM works perfectly on my notebook. :) I really don't know what was the problem.
Hello Gatter
Nice to read that now the connection is possible. :)
Probably your system was overloaded. ;)
Hi Alfaeddy,
It´s nice i can help you :D
Greetings from Germany
