Hello tac51415
Unfortunately, you can read on your screen no labels.
But it looks like the resistor R4 is concerned
Hi Eddy,
Wonder if you could point out which resistor to eliminate on the attached pics.
Chuckster
Sorry so blurry, I will try again if you like
Chuckster
- WP_000389.jpg (1.14 MiB) Viewed 8876 times
- WP_000388.jpg (1.21 MiB) Viewed 8876 times
Hello Cuckster
Wow. this board I have not seen
This is new to me
But if I see it right, despite the blurred image
then remove R1 in the yellow frame then it should work.
This is new to me
Hello Cuckster
Can you make the case even a picture?
Would like to know which design, the case has
Alfaeddy wrote:Hello Cuckster
Thanks Eddy, great work
Here's a pic of the case.
- WP_000390.jpg (859.24 KiB) Viewed 8867 times
My new cable arrived, and it's working properly.. I'll write down soon what was the problem..
Hello Gatter
Nice that you can connect to the controller now
Where did you buy the new ELM?
of my link?
of my link?
Hi Cuckster
Thank´s , ok its a Wifi ELM
This Boards ist new for me
Hi!
I have Fiat Doblo Cargo type 223 1,9 Mjet. ELM can not to conect to ABS (ELM + Green cabel). For the test I tried to use Vag Com + green cabel, all ok. In what could be problem?
Thx for answer.
Thx for answer.
You can read the Motor ECU , without the green cabel ??
Then i think first a Error in the green cabel
or second a Problem with your ABS ECU
