Gatter
Post by Gatter »
RESPONSE: ATZ
ELM327 v1.5
ELM327 v1.5
I can't install the interface with this driver: http://www.ftdichip.com/Drivers/VCP.htm
Only with this: http://www.silabs.com/products/mcu/page ... ivers.aspx
Hmmm! :?
strange :roll:
Gatter
Post by Gatter »
OK, no problem..
I've ordered a new one. After 2-3 weeks it must be arrive. So i'll come back here again. :D
leomuz
Post by leomuz »
Hi I have an interface V1.5a, same picture red card in the previous post, I remove a R04 resistor, so I can connect to CAN and service interval reset, I can modify a last service date or das till next service but I CAN'T reset KM when I execute next service km reset or next oil change km reset inmediatelly I receive FAIL.
Just in case number of service are in 7 service interval 10,000 KM
Distance till next service are in 0km and fail too trying change it.
Car Info
Fiat Idea 1.8 8V year 2006
All other option work without problem.
Thanks so much in advance
Leo
raf39
Post by raf39 »
I am French and I possessed a fiat 500.
I would like to make a reset on the meter for my drainings.
Which cable is necessary me it to make this discount(delivery) has zero.
Thank you
Hello raf39
Do not have an interface?
For the Fiat 500 you need an
ELM
http://www.ebay.de/itm/160996649487?ssP ... 1423.l2649
This ELM has no Bridge Resistor, the Problem with many other ELMs
and the A3 adapter (yellow)
http://www.ebay.de/itm/151015670657?ssP ... 1423.l2649
If you order this, send a greeting from me (Eddy) to the seller
raf39
Post by raf39 »
merci.réponse rapids(express) .bonne year has all
dean21
Post by dean21 »
Hello I have this elm327 ,can I remove only resistor 04, or must to solder some resistor and capacitor on the can line
Widerstand markiert.jpg (92.03 KiB) Viewed 14204 times
And also have this bluetooth elm327, is there any resistor to must remove.
Thanks a lot.
Hello Dean
On usb ELM is the red marked Resistor the right to be removed!
Otherwise there is nothing to change.
On Bluetooth ELM it is on the back of the board of the resistor R1 (121)
must be removed.
dean21
Post by dean21 »
Many thanks Alfaeddy, for the bluetooth elm, in my version the resistor R1 is removed ( I didnt remove) but still cant work can system.
Maybe is eobd plug problem pinout.
