Grigo112 wrote:Hello. I have 1 ELM327 1.5, and I have some problems, the elm refuse to conect on my AUDI A4 B5 1997 airbag modul, ABS modul, only engine (I have Airbag light on and I want to turn of or see the error cod), on Ford Fiesta 2002, Petrol same story, ELM conect to engine, but on the ABS no. I attach some pictures with my ELM, please say me what I need to do to can conect at all moduls. Sorry my english. Thanks
For VW, Audi, Seat & Skoda group you need VAG COM KKL 409.1 interface or VCDS 11.11 (or newer) interface or VAS 5054a (with VAS PC or ODIS software) interface. Search on eBay and you will find a lot of clone interfaces. Keep in mind that you can buy also originals but they are expensive.
For Ford you need ELM 327 interface (USB version) and software from this web site: http://www.forscan.org/.
Do hope was helpful. ;)
full approval :) :)
chefadrian
Post by chefadrian »
Hi guys. Hoping you can help. Trying to connect to CAN on my 147. Just need to know what I need to remove
https://lh3.googleusercontent.com/-2EQV ... AG0140.jpg
https://lh6.googleusercontent.com/-WJFq ... AG0141.jpg
Thanks in advance
Adrian
What problem you have while reading your 147?
In addition, this resistor (red marked) be removed if you can not produce a CAN connection
This interface has been repeatedly described here
IMAG0140 markiert.jpg (75 KiB) Viewed 11448 times
anonimo76
Post by anonimo76 »
Greatjoe wrote:Hi,
I have tried looking for my ELM 327 bluetooth module on this tread but can't seem to find it (The thread is so long now).
Here are photos of the adaptor, Does anyone know what resistor I need to remove on this in order to access the body computer?
Hi, I have the same problem connecting to the SERVICE with the Lancia Ypsilon '06 1.3 (MES 1.3 registered & elm327 v. 1.5, connection engine ok):
viewtopic.php?f=5&t=1493&start=850
viewtopic.php?f=5&t=3860
How did you solve? someone has solved?
thanks
Unfortunately, there are no other possibility for you,
Open the ELM and find this bridge resistor and remove
This ELM we had several times already but here you have to look yourself
set or an image.
Edit:
Unfortunately, it is not so, which was built the same board in the same packages.
anonimo76
Post by anonimo76 »
canyou help?
Sorry in this Thread is the same Interface
and I find not an bridge resistor
viewtopic.php?f=5&t=3860#p12879
Sorry
anonimo76
Post by anonimo76 »
connects directly to the engine ....
nothing SERVICE :(
Thanks anyway
Take now please a multimeter to pin 6 and pin 14 and measure the resistor between two pins
Then you can measure whether a bridge resistor is present.
Edit:
Otherwise, I would have the board in front of eyes to see the curves.
I had already tried unsuccessfully in the other post
