Hello locdogbg
No ;) it's not a Chinese conspiring :lol:
It must be due to the software!
For other software have also no problems with this bridge resistor
I only know Multiecuscan which has the problem!
Why is this so??
I do not know
inzane19
Post by inzane19 »
Can someone help me with this one?
It dous not connect the ECU for my opel (vauxhaul) astra G 2000
Bluetooth is working fine only toque say`s no connection with ECU
http://www.ogame-ryf.nl/image1.jpeg <-- Back
http://www.ogame-ryf.nl/image2.jpg <-- Up side
http://www.ogame-ryf.nl/image3.jpg <-- Device
I do not understand your problem?
Would you read an Opel Astra?
This is about Italian cars!
With what software? Torque?
This is about Multiecuscan!
An Opel can not be read with MES
And just for Multiecuscan in the CAN bus, the board must be modified.
inzane19
Post by inzane19 »
Hm i`m sorry.. Didnt reconize it was an italian car forum :P
Google send me directly to this board and this treath.
Then i saw the pictures about editing en thought maybey he know wat to do with my device.
The problem: I want to read car statics but the device wont reconize my ecu.
I tried it with torque but the problem is @all programs i tink..
I understand if you dont answer this questen :) i had to read before posting :P
One answer would be no problem if I could help you?
But your problem has nothing to do with the issue here.
That's why I wrote you this is not about torque here.
andrea58599
Post by andrea58599 »
Greetings to all, I wanted to know if it was possible to have a board of this type of elm 327 usb wifi-that connects perfectly but sees only the engine and transmission.
The machine is a quaver 1.9 150 cv 2008.
Here is information to all why 121 resistor is installed in all ELM 327 clone interfaces.
All clone interfaces have been made for cracked ELM ScanMaster software.
When you have installed this 121 resistor ELM ScanMaster works perfectly.
When you remove this 121 resistor: ScanMaster sometimes loses connection or it can not connect that easily and on some cars will not connect at all.
I am telling you from experience because I have original ELM ScanMaster software and some ELM interfaces with 121 and without that resistor.
andrea58599
sorry but I can not insert images
andrea58599
here is the photo of my wifi-usb elm
andrea58599
and here is the back
