Hallo Seb
you can send me an Buyer Link from your ELM Interface ??
Hello Eddy,
Sure. I have taken this one sold by iscanning and delivered by amazon (in stock, delivery was made in 2 days, great).
http://www.amazon.fr/gp/product/B004KL0 ... er=&sr=8-2
Do you think that it would be possible that serial connection can work for can bus and not for KL because a param is incorrect (baud rate, latency...)?
One other thing, do you already have installed ftdi driver for a bluetooth interface and not an USB? I have tried but windows doesn't seems to like it (warning flag, device don't start)...
Thank you
Seb
Thank you
Seb
Hi, this is possible.Alfaeddy wrote: Hello
This is not right
R14 is not a problem at this interface
if this interface can read Multiecuscan no CAN bus it is up to
R4 but is not present at the interface in the picture
This interface should be in the picture without problems with MES can read the CAN bus
I'm just saying that my car alfa romeo GT did not work until I did not remove the resistance R14 and R4 then everything was fine.
On other cars it may not work
gondal wrote:Hi, this is possible.Alfaeddy wrote: Hello
This is not right
This may well be the R14 you could solder again
the function it probably has no effect
except that an LED is not lit
But as long as you can work with it that's OK
Hi Seb
The one ELM interface can read the CAN bus
KWP2000 but no I've never experienced?
Therefore times trying to install this driver
Hallo Eddy,
I have already tried to install ftdi driver, but the driver don't start. (USB version for a Bluetooth model can probably explain that).
I have received the RTA of my car and engine module is correctly connect to pin 7. Steering is on pin 9 which is not connect on my interface, so it seems normal to not access to it.
Can I suppose that my interface K line works because I have succeeded to connect with a 2002 stilo (perhaps it doesn't use this line)?
I don't know what can I do... Perhaps I need to buy another interface, USB this time to avoid Bluetooth problem, but I don't know if it will solve my problem.
Thank you
Thank you
Hi Seb
Unfortunately, I also do not know, but suspect still setting error?!
I would try it once with another (USB) interface.
Maybe your BT ELM is indeed defective.
Hello Eddy,
I have tried with torque on Android. My interface has blinked like a Christmas tree but it hasn't worked.
Connexion was ok but ECU com was not functionning.
So I'm affraid that my elm is really defective. Only can line work but k line seems dead.
I don't know if I can fix it.
Anyway, thank you very much for your help.
Seb
Seb
Hi Seb
Have you written all the time by the software "Torque"???
Or do you have the same problems with MES??
No no, all my previous post was with MES.
I have just tried yesterday with torque to conclude that my interface is defective.
But as I have achieved a connection with a stilo, I don't understand at all.
Regards,
Seb
Regards,
Seb
