dpf replacement job does not work - Alfa 159 1.9 jtdm
torsten74
Post by torsten74 »
Hello everyone,
I'm not quite sure if this is the right place to post, but I will try.
I've got the following problem:
I changed my dpf (particular filter) and after that I wanted to do the job for setting the replacement of the filter in the ecu.
But everytime I start the multiecuscan-routine for the filter replacement, the status window comes and says after about 10 seconds "status: unknown" and then "ready".
When I check the parameters after that, the mileage travelled since the last filter replacement is not set to 0 as it should be.
Is it possible that I do something wrong?
Or is there a bug in the software?
I am very thankful for any help.
Regards, Torsten
