NO ECU connection
NO ECU connection
Hello everybody,
I am new here to this forum. Recently i bought an ELM327 v1.4 and a KL they came with an red, yellow and green cable.
I installed the drivers. I am running win 7 pro.
When I try to connect to my '99 Multipla 1.6 16v multiecuscan comes up with an "no ECU connection" message.
There is during te proces only one red light on, on my ELM interface.
Contact is set to "MAR".
Can anybody please help me further?
Re: NO ECU connection
Do you have the appropriate interface (KKL or ELM) set in MES / settings / interfaces?
Have you set the correct COM port?
You have set the Latency Time to 1?
where do i have the possibbility to set the latancy to 1?
i have set the com ports.
i mached the baud rate in my windows hardware control to 38400.
i tried for a couple of days now but still no connection
Hello berkel
Hmmmm?
Let the adapter cable away
and put the ELM or KKL directly without adapter cable
For your ECU you will need an adapter
And ABS and airbags are to be read only with the KKL interface.
And as a last option I can think of yet, try a different laptop.
Since the ECUs from your Multipla
Magneti Marelli IAW 49F Injection (1.6) | INFO | DTC | PRM | ACT | ADJ | KLELMOBDKey
Magneti Marelli IAW 4AF/4EF/59F/5AF EOBD Injection | INFO | DTC | EX DTC | PRM | ACT | ADJ | KLELMOBDKey
also work with the free version of Multiecuscan.
Hmmmm?
Hi AlfaEddy,
i thought i must connect with an green adaptor kabel between the car and ELM. But i wil try with out it.
Is the whole software pakkage normaly plug and play?
Still no luck.
tried different ELM adapters, other laptop, bunch of settings but i can not connect to my Multipla.
Can it be a driver problem? When i try to connect to the ECU nog other LED's on the ELM start to flash. I would expect that there would be some flashing lights.
Hello berkel
The green adapter for ABS, and if equipped, steering, xenon and some
further controls required.
To connect to the ECU you can use both interface directly.
Hello berkel
pity
Then I suspect that your interface is broken. !
But you still a KKL interface?
try this
pity
try this
yes i also have a kkl. I try it later on the day.
Thanks for the reply's eddy.
Does your KKL interface work?
