ME 2.1,ME3.1,Xenon Adjustment and Automatic Gear 166
frank37
Post by frank37 »
Hello Yani,
please support for 166 ME 2.1,ME3.1 ECU, Xenon Adjustment and Automatic Gear.
thx
Frank
klimekkk
Re: ME 2.1,ME3.1,Xenon Adjustment and Automatic Gear 166
Post by klimekkk »
What you mean by xenon adjustment? Is this possible by ECU?
I adjusted manualy in my Alfa 166 - you have to use hex (6mm?) key and turn screw on top of electric motor - it's huge regulation this way!
frank37
Post by frank37 »
for Xenon is adjusted via the diagnostic plug, there was no bolt on the motor.
frank
klimekkk
Post by klimekkk »
Hmmm. If You talking about bixenons it may be correct. Xenon before FL has manual regulation by this bolt: http://img689.imageshack.us/img689/6144/xenon2xi.jpg
frank37
Post by frank37 »
Yes, but Xenon is adjusted via the diagnostic plug and the Fiat Examiner.
Frank
devc
Post by devc »
The ME 2.1 is the same as the ME 7.3.1 but without the two Lambda sensors in the exhaust branches (Bank1 & Bank2)
All the other sensors & Actuators are the same. Pre 03 156 2.5V6 (ME 2.1) & post 03 156 2.5V6(ME7.3.1)
The same diagnostic can be used.
156V6
Post by 156V6 »
devc wrote:The ME 2.1 is the same as the ME 7.3.1 but without the two Lambda sensors in the exhaust branches (Bank1 & Bank2)
Does that effectively mean I could pick any of the cars listed that use the 7.3.1 ECU to communicate with my 2.1 ECU?
Nilsx
Post by Nilsx »
Yes, that'll work. I used the GTA ECU, you'll only get a warning about the ISO code.
But i would also like to see specific support for the ME 2.1 ECU.
