software purchse
rafi532
software purchse
Post by rafi532 »
hi,
I own 147 1.6 120hp and I'm about to buy the multiecuscan software in order to fix flashing odometer and maybe for another functions that I'll find usful.
I have simple OBD-II cable that connent properly with the free version but can't connect the airbags (and one more function that I don't remember right now).
I'd like which cable I car order that will connenct to all elements that the software support ?
Re: software purchse
Post by s130 »
According to the Supported Vehicle Data page on the website then your air bag requires a simple KKL (VAG Com) cable and adaptor cable / modification.
Suggest you read this page:
to understand what is supported and what hardware is required.
Also the see the Authorised Distributors page:
http://www.multiecuscan.net/Distributors.aspx
Hardware packages, components, leads etc. bought from these source are known to work with no issues.
rafi532
Post by rafi532 »
Can I be sure that this cable will work fine:
http://www.obdspecialist.it/dettagli.as ... z2BBti2Twh
Post by s130 »
I should work OK and also has the advantage of already being modified for the different pin connetions being required.
It is unusual for a KKL cable to not work correctly unless it uses an odd USB to Serial conversion chipset and drivers.
rafi532
Post by rafi532 »
For the avoidance of doubt, is this interface (KKL) support special functions such as PROXY ALIGMENT ?
Reading with this KKL interface you can ABS, Airbag and ECU on your Alfa 147
But it is not for the Proxi Aligm. / Reset service etc. suitable.
For this you need an ELM, or OBDkey CANtie Interface
But no KKL
rafi532
Post by rafi532 »
Can you recommand on specific cable that will do it.
I know there are links here but I'd like to buy the cheapest cable that can do the special fuctions,
instad of asking every time that I found something that I think it's ok.
Post by s130 »
You ask a hard question about recommendation.
I gave you the Authorised sellers links.
I use and can therefore recommend Gendan products for UK.
Other people will use 'other' makes/products and will likewise recommend what they use is they have had no problems.
I don't believe anybody has compiled a chart of known working devices vs devices that work with mods (mostly cheap Chinese clone kit) vs devices that don't work at all.
