2008 fiat bravo airbag light reset
gateshead
Post by gateshead »
hi i have a 2008 fiat bravo its had its airbags and seatbelts replaced. i have tried to reset the airbag light with no luck using multiecuscan. can multiecuscan deleate the dater or would the ecu have be sent off. also all the airbags have resistance ohms but seatbelts have 0.00ma could the seatbelts have faulty wiring. thanks kevin
Aron96
Re: 2008 fiat bravo airbag light reset
Post by Aron96 »
Hello gateshead, you should see in diagnosis airbags which gives you the error then you have to see when you crash indicates that after 2 crashes does not make you reset the error so you have to replace the airbag control unit, or if you know someone who can reset the eprom in the airbag control unit
greetings
