FES 3.5 Problem
Gavra
FES 3.5 Problem
Post by Gavra »
Today I download version 3.5 registered version and it kills all my USB ports :@ I thought it was something with Windows so I did a system restore but USB ports are still dead. Then I download fresh copy on my desktop and installed FREE version and it kills USB ports on desktop too.... :roll: :evil:
netbook with registered version is DELL1018 with W7 on it and desktop is XP SP3 ...so its not related to system.......after that I received error COM PORT 3 access is denied.....I send report from both computers using red banner in FES interface.
Hope there will be solution soon.......
Gavra
Re: FES 3.5 Problem
Post by Gavra »
over 40 views and 0 reply?!
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at  . (Object , EventArgs )
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Multiecuscan2
Assembly Version: 3.5.0.0
Win32 Version: 3.5.0.0
CodeBase: file:///C:/Program%20Files/Multiecuscan/Multiecuscan2.exe
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Management
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.Data
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
here is windows log of error btw now I CANT use OPCOM,VCDS on this netbook also and they are licensed too........
I think I deserve reply ......
Re: FES 3.5 Problem
The reason for not answering is probably because noone has an answer...
Anyway, I don't know how it is possible for any software to kill the USB ports. Also, any problem caused by a software should be resolved when you restart the computer.
Are you sure that it is not some kind of virus, or driver updates which have caused this problem?
Gavra
Re: FES 3.5 Problem
Post by Gavra »
yes I am sure this is not caused by any kind of virus. Everything works fine until I start FES.....first attempt to connect on a car or test interface I get ERROR COM3 access is denied....and nothing else can be plug after that.....just don't see USB port. When I manually remove FES from registry after uninstall then it works until I install it again.....I have been trying that for 2 days now and found pattern . I don't know why that is happening because everything worked fine until update to version 3.5...... if u need more info tell me which log to capture and I will send it to You. Until now I was very satisfied with FES compatibility on W7 platform ....I know this is a minor bug but it's kind of annoying ....
Juggers2k
Re: FES 3.5 Problem
Post by Juggers2k »
Are you up to date with all the .NET framework service packs and updates?
Gavra
Re: FES 3.5 Problem
Post by Gavra »
Yes .....DELL came with W7 licensed and automatic update selected......
2angel
Re: FES 3.5 Problem
Post by 2angel »
So, no one has any idea about this problem.
Ovioslly it isn't conected with OS.
I download too free 3.5 just for testing, I dont have problems with FES.
MKSA
Re: FES 3.5 Problem
Post by MKSA »
No answer because no one else has the problem !
