pinuccio wrote:Hello everyone, sorry for my English but I am Italian.
They are holding a spear Ypsilon 1.3 Mjet of 2008.
I wanted to know what cables I need to maximize the potential of multiecuscan.
thanks
According to http://www.multiecuscan.net/SupportedVehiclesList.aspx
you need an ELM 327 interface and adapter cable A1 for your LANCIA YPSILON '06 1.3 JTD!
You need an ELM 327 ver. 1.3 or ver. 1.4!
Hope it was helpful! ;)
amfalconer
Post by amfalconer »
Hi all,
Now I'm confused as hell!
I have the same ELM interface as described by sprint750 (pics on 2nd page of thread). His seems to work fine. I bought this a fortnight ago from the ebay user newerer.
The Car is a 2003 Alfa 147 1.6TS. When I try to connect, I can access the CANbus and perform a Proxy Alignment, and get all the CAN Info I need.
I can't however, access the climate control module, or the service light reset. I already have a modified KKL cable, which i modified myself, so don't need the ELM to access any of the Airbag/Engine etc.
Anybody able to tell me if it's actually possible to access this with my car? and if I need to make any mods to my interface?
Andy
pinuccio
Post by pinuccio »
thanks
Grazie per la risposta, provvedere a comprare tutto
Franky
Post by Franky »
hello, can you help me for this model?thx
I have to remove the resistance you have on your screen marked
red circle
ELM R04 entfernen.jpg (95.41 KiB) Viewed 10253 times
Franky
Post by Franky »
thank you Alfaeddy it works .
Did you like to help
djbase
Post by djbase »
Is there a known problem with the newer ELM 327 bluetooth odb2 modules ?
I can read out the CPU, but don't have the adapter cable 3 yet for my alfa giulietta.
I've got the pics here : it's version v1.4b
tnx !
djbase
You can use this Bluetooth interface the ECU read your Giuiletta?
Then, your interface is not described in the CAN error
For all controls on Giuiletta be read via CAN
Buy yourself the described cable 3 then you should also be able to read the other controls.
Or, you CAN build a switch in the interface
For accurate visual inspection make a picture with plug is removed
djbase
Post by djbase »
Yes I can read the ECU.
ECU ISO Code: ** ** ** **
10/04/2012 23:33:10
CONNECTED TO:
ALFA GIULIETTA 2.0 MJET 16V
Bosch EDC16C39 CF5/EOBD Diesel Injection (1.6, 2.0)
ISO code: ** ** ** ** **
Tekeningnummer FIAT: ********
Nummer HW: 0281017784
Versie Hw: 00
Nummer SW: 1037516796
Versie SW: 4541
Nummer homologatie: *****
Werkingstijd (EEPROM): ****
Bedrijfsduur: ****
READING ERROR CODES:
No fault codes"
Is what I get in the log.
But i don't have the yellow cable, I've just ordered one. So I'l have to wait to test the CAN-info
So probably I don't need to desolder something in the module ?
Tnx!
djbase
